1992 LEXUS SC400 BRAKE Problem ????
Old 10-16-07, 09:54 AM
dirkdiggle
dirkdiggle's Avatar
Default 1992 LEXUS SC400 BRAKE Problem ????
I just have a quick question regarding the brakes on my 1992 SC400.
I just recently replaced brake pads all the way around the car and the front two rotors. Rear rotors where fine so I left them alone. During the course of replacing these parts I discovered that I had 2 sliding pins that where frozen. One pin on the front right caliper and one pin on the rear left caliper. I fixed both pins and now they move/slide as they should.
My question is as follows:
What would cause my brake pedal to feel soft/sponging when I first apply the brakes?? Every time I come to a stop the pedal is soft when I first press it but if I let off the pedal and press again it is nice and hard like it should be?? It is the same everytime, the second time I press the pedal the resistance feels normal(hard)?? Any ideas are welcomed??
air in lines?
moisture in lines?
Differnet brake component failed or failing?
It always only takes 2 presses to feel normal and never 3,4,5!
Old 10-16-07, 10:35 AM
bigmalik00
bigmalik00's Avatar
air in lines..you have to bleed all four sides..
Lexus082
Suspension and Brakes
10-13-12 05:40 PM
Lexus082
06-21-11 05:39 PM
V8drummer
02-19-06 05:58 PM
Petkeo
Maintenance
05-21-02 06:28 AM
Quick Reply: 1992 LEXUS SC400 BRAKE Problem ????
