squeeking i need ur help!
Old 10-22-07, 06:27 PM
fwynn
fwynn's Avatar
Default squeeking i need ur help!
okay.. my car .. has been squeeking for some time.. and i need ur help!
when im driving.. i can hear it squeeking and its not the suspension..
it goes EE EE EE EE EE EE EE
and not a long EEEEEEEEEEEEEE (doesnt matter if its bumps or straight)
it will squeek anywhere..
squeek is on the rear left
im 99% sure its the brakes.. but wanna make sure.. and wanna know what to do first!
when im on the brakes.. (lightly press.. not to slow down or anything) the squeeking stops..
any suggestions? need to replace? need to fix? THanks
Old 10-22-07, 06:32 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 10-22-07, 06:33 PM
Hil
Hil's Avatar
could be ur rotors dood. mine had the same problem and just needed the rotors to be smoothed out
Old 10-22-07, 06:49 PM
fwynn
fwynn's Avatar
thats what i was thinking too.. gunna. maybe upgrade? iono..
LS brakes..
but does LS brakes clear sportmax 962 rims? 18"
also i dont get that pic OLT :[ a trap.....
Old 10-22-07, 11:01 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
LS brakes..
........cmon now felix, think towards the corner of the box at least......
you said you heard squeeking, how to stop that squeeking......mousetrap
Old 10-22-07, 11:05 PM
fwynn
fwynn's Avatar
oh..
wow
im slow
HAHAHAHAH i get it :P
Old 10-23-07, 12:45 AM
SC30096
SC30096's Avatar
check your the muffler support. there are 2 bolts that are connected to the underframe that hold the rubber hanger. both of my bolts were stripped and when i hit bumps it would squeek. I had a mechanic make new threads and tightened them up good. now im squeekless, I was getting ready to changed my rubber bushings until one morning I started my car and i heard the squeek so went to check wiggled the muffler around and found the bolts loose and that annoying squeek
Old 10-23-07, 10:10 AM
vwynn
vwynn's Avatar
the sqeeking isnt caused by bumping. ive noticed when the car roams forward on D it starts to sqeek at a certain rotor position.
im thinking it might be casued by low pads + warped rotors. but i dont know since when i press the brakes enough so that the lights turn on only it doesnt sqeek anymore.. hmm something is wierd.
Old 10-23-07, 11:06 AM
TheMole
TheMole's Avatar
For starters, check the dust shield back there and see if its touching anything.
Old 10-23-07, 03:06 PM
Sly Guy Yu
Sly Guy Yu's Avatar
dust shield is more of a scratch. A squeeking prob the low pad indicator. change pads or get those ls400's
Old 10-23-07, 03:07 PM
Sly Guy Yu
Sly Guy Yu's Avatar
also is it coming from the front or the rear?
Old 10-23-07, 09:53 PM
fwynn
fwynn's Avatar
rear left..
squeeking happens when i DO NOT BRAKE!
and no its not the suspension..
Old 10-23-07, 10:03 PM
TheMole
TheMole's Avatar
Another thing to look into is your wheel bearings. Jack the car up on the rear left and see if there is any sort of play in the wheel.
Daniel N
16
10-09-08 04:17 AM
Darein23
Suspension and Brakes
04-27-08 09:28 PM
rtk7
08-18-07 10:05 PM
rajah996
Southeast
11-27-03 05:16 AM
jersey1
04-09-03 09:46 AM
Quick Reply: squeeking i need ur help!
