Tsib Brakes
i tend to see a lot of people spelling break.. it's BRAKE...
is it as excessive as before? i recently had mine changed and i don't see it as excessive as before.. brake dust is normal, but if you're seeing it as bad as before, either have the dealership check it again or save money and get aftermarket brake pads..
You might've gotten the same pads. Check out the pad #'s and compare it to the TSB's #'s and see if they match. Also, you can take a picture and if it's green then they changed it if not it's the same. Good luck!
I haven't done it yet, but those that have say there is dust, but only the amount that you were getting before on the rears. If that's not the case, maybe andyroo's right.
