Still have scraping sound!!!!
Old 11-01-07, 01:06 PM
denvergs4
denvergs4's Avatar
Default Still have scraping sound!!!!
So went out and bought new v-clips and installed them but I still get a scraping grinding sound when I brake softly, like there is movement in the pads or caliper.
It doesn't make the sound when I brake at a higher spead just when I am slowing down to brake. I did buy the ceramic pads so I just don't know what else I can do.
Anything else to try would help.
Thanks
Old 11-01-07, 01:36 PM
GSteg
GSteg's Avatar
is the scraping noise constant or does it pulse?
Old 11-01-07, 01:39 PM
denvergs4
denvergs4's Avatar
Constant until I brake really hard
Old 11-01-07, 01:40 PM
denvergs4
denvergs4's Avatar
Sounds like metal on metal and scrapping but no scrape on rotor and my rim looks fine.
Old 11-01-07, 01:53 PM
GSteg
GSteg's Avatar
Perhaps you should take a look at your brake shield. It might be rubbing on the rotor. I know i had that problem awhile ago. I bent the shield where it was touching the rotor and the noise went away.
Old 11-01-07, 01:59 PM
denvergs4
denvergs4's Avatar
wouldn't that scrape all the time then? This just happens when i slow down and lightly touch the brakes.
Old 11-01-07, 02:01 PM
GSteg
GSteg's Avatar
No. Mine was scraping sometimes.
Mine was making sound at lower speed though.
Old 11-01-07, 02:04 PM
cpone
There can only be One
cpone's Avatar
Could it be a bent rotor?
Old 11-01-07, 02:09 PM
denvergs4
denvergs4's Avatar
I guess it could be how would I find out if that was the case?
Old 11-01-07, 02:10 PM
denvergs4
denvergs4's Avatar
It doesn't look bent or even warped!
Old 11-01-07, 08:05 PM
dung0981
dung0981's Avatar
you can not tell by just looking at the rotor. Get it resurface when you install the new brake pad
olddog
Suspension and Brakes
37
02-15-20 04:52 PM
Epic123
13
10-30-11 04:30 PM
Ldogg123
28
08-27-10 01:25 PM
ashtray
10-22-08 03:23 PM
Quick Reply: Still have scraping sound!!!!
