Daizens? What a difference!
Well after a long wait of acquiring suspension parts(Daizen sway bars,Daizen bushing kit, tierods/ball joints, and roll center adapters), what a difference in the handling!My car feels and handles brand new!I have yet to get an alignment due to getting the car back today, but the drive home from my mechanic was fun within itself! The steering handles alot better and the response of lane switching is very noticeable! The clunking noise(Bad Bushings), I was experiencing on the driver's front side has stopped and my braking has even improved considerably! The entire suspension on the frontend feels very responsive and has even reduced the noise from the Tein Flex coilovers, when going over bumps at increased speeds. I wish I had done this sooner! I'm curious to see how well she handles in curves and corners at high speeds?My next upgrade to the suspension would be the front/rear braces along with the 6 links!
My mechanic did point out to me that my left rear upper control arm bushing has a slice in it and stated that there wasn't any play in it, but recommended me replacing both sides soon! There was some seapage noticed from the water pump on the front stock sway bar, which indicates it's time for the 90k service? Gotta get this done soon (82,000 miles and climbing!).
I'm going to get a tire rotation (dismount/remount) soon, along with an alignment! It's still early to see how well the rca's will help out with the tire wear, but I'm glad to know that they are installed!
For those of you who have yet to do the Daizen bushings, tierods/ball joints, get it done! Just wanted to share the early feedback with my fellow members!
Thank's!
Unfortunately, I couldn't wait any longer for them to come in from back order, so I went ahead with the install of the other parts. Hopefully, when they do arrive I'll be able to land a set. I only drove it for a short period of time from my mechanic to home and it was a blast doing that! I even got tested against a BMW M3 on the way home, and I smoked him weaving in and out of traffic. (He got caught in the traffic!) He would have smoked me if it wasn't for the traffic though! The car handles beautifully! Thank's, Will!
Great feedback
I have the Daizen sways with poly brushings (courtesty of Henry aka Rominl) sitting in my garage patiently waiting for ball joints/inner and outter tie rods and the whole Daizen control arm brushing set and HOPEFULLY the steering rack.
I cant wait to get these installed, but I want to wait until I have everything so I can just install it once and call it a day.
I understand!
Great feedback
RCA probably gives you the suspension travel you lost also with the lowering. I want to do sway bars+bushings so bad too but after all it's said and done, it looks like it'll be expensive.
How are the Daizen sway bars? I know someone on here had one and snapped in half, yikes. I hope that doesnt happen to you. I dunno why but my sway bars seems like it's lost its full effect after I lowered my car...maybe I need the endlinks to be extended or something.
Daizen sway's?
Both daizen and TRD bars have snapped before. There could be lots of reasons why they did. But once or twice does not make it a trend for the bars to break.
wringo, what setting do you have on your sway bar?
If you're on the stiffest setting, take your car around an sharper turn. You'll feel the bars tightening up to reduce body roll. I'm on stock bar right now and I dont dare to corner faster than 20mph
After awhile, you just get use to the handling. The effects are still there...you're just immune to it
wringo, what year is your car? I ask because I have an '02 and that seems like a lot of suspension work for a 5-year old car (in my case that is). I totally overhauled the suspension on my SC, but that car is 15 years old so it obviously needed it.
