tsb and brake dust
tsb and brake dust
Just had it done last week. Cleaned my wheels on Saturday. Its been 5 days and there are more brake dust than expected. Not as much as before, but definitely more than the rear wheels. Are you guys getting same results?
Both the RWD (GSE20) and AWD (GSE25) use the same brake pads front and rear. Like joeb427 said, check your repair order and make sure they installed the right pads. I had mine done about 3 months ago and I've never regretted it.
i will check the repair order for # 04465-53030
Had my brake pads replaced also. Two edge sword to me. Yes, the dust is virtually gone now.............but the brakes are grabby and really so when cold. Brake stopping power appears about the same but it seems it takes less pedal pressure to stop..... Rotors wear I think is up..........not a good thing when they need to be replaced. Ouch!!!
i wonder if the 2008's come with the newer pads. i would think that would be wise
(unless the eprecentage of replacements is low, maybe most people just put up with the black dust?)
We have an 08' & have this issue as well.
