Sway bar effect on front/rear balance
Hello, everyone out there!
This is my first post, so please excuse me if I am not doing anything right/by the rules: it is not because of bad intent.
I have a 2001 GS430 with regular wheels.
I was considering the following handling upgrade:
* Eibach Pro-Kit Springs
* Bilstein dampers
* TRD sways.
My question is: does anyone know how the installation of TRD sway bars affect front/end balance? In other words, does the car oversteer / understeer more or is the original handling balance preserved?
I am asking because I am considering to upgrade the tires and possibly rims and want to know whether it would be OK to install wider rubber at the rear WITHOUT having a car that plows through the turns. My intent is to modify the car for the performance more than for looks, so anything that slows the car down or makes it handle worse I would like to avoid.
Anybody has some first-hand experience with that?
* Bilstein dampers
* TRD sways.
Vlad - I think the TRD sways perserve the factory built-in understeer. I chose the RMM/Intrax bars because the rear bar is adjustable - I like a little oversteer since I learned to drive on gravel/dirt roads & am used to hanging the tail out. Plus the stereo weight in my trunk made me pretty neutral when I had the factory bars & I wanted the option of experimenting.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Vlad,
I've got pretty much the configuration you're asking about including:
* Bilstein dampers
* TRD sways
plus I've got the TRD front strut brace. I only had the TRD sways put on last weekend and haven't had a huge amount of drive time.
Initial impression is that factory balance is preserved, but the car stays more flat when cornering. Much higher level of confidence and better road feel.
* Bilstein dampers
* TRD sways
