Steeing Rack Does it need replacement?
#31
I have the same problem my sc its a 92 with 180k. I for some reason dont think its the rack, i dont see why they would wear in every car like that. Ive seen cars with 250k that the rack is fine. I just got new bushings, im hoping thats the real problem, so far from all the info i read, everyone says bushings are the root of this problem. It makes sense imagine if the entire rack shifts when u hit a bump, then it would jerk the steering...........makes sense
#33
https://www.clublexus.com/forums/sho...d.php?t=208313
https://www.clublexus.com/forums/sho...d.php?t=264932
As for the front lower control arms, you can have new bushings pressed in or just get the complete arm. OEM Lexus ones are about $400 per side for the complete lower control arm w/ balljoints. You can also use 93-96 Supra TT arms which are only about $200 per side, but probably provide a "sportier" ride.
#34
i did the rack bushings, no help. i also think it got worse with my wider tires.
control arm bushings might help if you do both bottom and top.
i think this one will remain a mystery for a while
#37
replaced my bushings yesterday, it helped a little, but the problem is still there. it must be the rack......... when i had the car jacked up, i could turn the wheels easily by hand, ive never been able to do that before on any car............
#38
If you have ATF coming out under the boot, then yes you need a new rack. However, I think there are many people with this problem, where that is not the issue. The correct term for my problem is HORRID BUMP STEER
#39
hey guys this might help. I just bought another sc300 and the suspension on this one is super tight. The power steering rack has been replaced by previous owner with an entirely new oem unit about a month ago, meaning new bushings as well.
The car is a 5spd and the power steering doesn't seem to be as strong as my other car with an old rack+new bushings. the steering is nice and tight, almost perfect with the new rack.
so i took it to the road in dc that always makes my car swerve right when i hit the bumps (K street and 17th street). EXACT SAME THING HAPPENS IN THIS SC!!
I was hoping it wouldnt, but it did. exact same bump steer on a brand new rack.
I dont know what does it, I would be surprised if someone finds a fix for it.
Maybe send a letter to your senator to fix the bumps in the road?
#42
Under further trial and error, I went ahead and swapped out the upper control arms. It seems to have corrected the problem. I will further inspect the ball joints from the arms that are now off the car. I will continue update my findings after driving some more especially on the highway and coming to a moderate-fast stop on a bumpy, uneven road surface. So far the car seems to stay straight while driving unlike before. I have not replaced the rack yet, just the upper control arms and I do notice a difference so far.
