rotor resurface ?
A Lexus dealer resurfaced my rotors with the brake pad TSB and charged me a ridiculous $219 with tax.I biatched in and sent an email to the Service Manager and recieved a credit for that amount on my credit card a day or two later.
I would not allow anyone to resurface my rotors. If they are scored so badly that they can't be reused as they are, then they should just be replaced.
That said ... I would just change the pads myself anyway...
There's been quite a bit of discussion about the reasons not to resurface rotors, but here's a good opinion from lobuxracer.
https://www.clublexus.com/forums/sho...4&postcount=53
I've had rotors cut on vehicles before and never had a problem.
If he has 20K miles on his rotors versus say 5K miles,they most likely will need a cut rather than a 5K rotor sand paper scuffing,IMO..
Another Lexus dealer ripoff.
My dealer charges $219 to cut two rotors when you can buy two OEM rotors for a list price of $259.56.
According to Lexus of Pembroke Pines online parts catalog.
http://www.trademotion.com/partlocat...06&catalogid=1
There's tons of things that you can do without any problems, but that doesn't mean you should do them. I just replaced my OEM front pads with the new low dust pads at 24K miles, and I didn't resurface my rotors. They did fine, and I didn't have to give up any of my precious rotor mass.
When I experience any problem with a resurfaced rotor,I'll just buy new rotors.
At 24K miles,did you check your runout before installing the pads or just throw the pads on and they feel good?
I didn't check runout, but there are no vibrations, so I wouldn't suspect any issues.
FWIW, if there was excessive runout, then I would definitely throw them away. Resurfacing a warped rotor would be silly since the resurfacing wouldn't straighten the veins so they would warp even quicker the second time.
Resurfaced rotors will also use up a lot more pad material during the bedding process, so it isn't just the rotors that are wasted. If you bed in new brakes on resurfaced rotors, then again on new rotors, you might find that you've thrown away 10% of your new pads.
On your 24K change...
I've read people here had the brake pad TSB done and the dealer resurfaced or gave then new rotors for free.I'm betting most with under 24K miles.
Do you think the dealers would do resurfacing or rotors for free that if just throwing pads on would work?
You may be fine and I hope you are but I'd want to know for sure.
Obviously and the dealer would have told me if that was the case.A rotor usually can be cut once unless there is excessive runout.
The dealer probably would have resurfaced them. That's why I didn't take it to them. In situations like these, the dealer will almost always do whatever works out best for them. If they had new rotors in stock, then they would probably replace them, and charge Lexus for them. Otherwise, they'll resurface the rotors, and charge Lexus for that.
It's this kind of crap that made me vow to never pay a mechanic to do something that I could do myself. The only work that I've NOT done myself in the last 13 years was a warranty transmission replacement. I would much rather do it myself so I know it's done right even if it would be "free".
