help remove my lugnuts!
okay..so i attempted to change my suspension again..i was able to successfully change my coilovers in the front with only minimal problems..but then i got stuck with my rears! its not even the part when i remove the shocks or the bolts! its the freakin wheel i cant get off! it seems the owner before me put on the lug nuts a bit waaay too tight..i ended up bending and kinda ripping it..i dont have standard lug nuts either..its kinda similar to a locking one..but yea..i am definitely going to buy new lug nuts..i thought these were kind of cool, but now not so much..even the key is starting to bend..any suggestions on some good lug nuts? heres the pictures btw
heres what they look like
heres some pictures of my key..you can see where its kind of bent..it almost doesnt remove the lug nuts now..any ideas on some tools i can use instead of this?
and heres my kinda ripped/bent lug nut..ouch! how am i going to remove that? any ideas?
and heres my kinda bent one..its not so bad right now..but i dont want it to get worse later
and oh yea..thanks in advance for any help! i hope after this i dont have any problems! i really want to lower my whole car..not just the fronts like i have now..haha
thats what i was kind of afraid of..taking it to a shop..i guess thats what ill have to do..and i did soak it with some pb blaster..thats why its all orange/yellowish..i was able to remove the otherside just fine..its this side that came a bit tough..i was so close to doing my full suspension!! gaahh!! so i guess ill take it to les schwab to get it removed..it shouldnt cost much though..should it?
oh...i just thought of something..what if i took a dremel and cut the other side of the cracked one and created some kind of a flathead screwdriver thing? you guys think that'll work?
yea..i think i learned my lesson that way..haha..or at least not this brand..i heard gorilla ones are pretty strong..well im off to les schwab to get my lugs removed..dang it! i hope there's no more problems with my coilover installation again
yea..i was thinking about that too..wouldnt do so well on the wheels..im gonna take it in on monday..time got a bit crunched today..so i wasnt able to take it in today..my next lug nuts are going to be some nice gorilla ones for sure..they look like those last for a long time..considering they're freakin lifetime warranty! they better!
and les schwab said theyd do it for like $40 an hour..which should take long since its only this wheel im having troubles with..then i think they said about $2 per lug nut from gorilla..im gettin all gorilla..maybe even all locking ones..still unsure
Location: Sideways on the Yellow Brick Road! < Thats KS!
First, use a large allen wrench on the good ones to get them off with out damage, save that messed up tool, you will need it. You need to take it to some place that has a mig welder. You can have a standed nut tack welded to the bad lug or better yet put the messed up tool in it and put a few tacks on it. Works every time! Use several layers of Duct tape or leather to protect the wheel. This is the same method used to remove wheel locks that have stripped or key is lost. Have done it myself and it works.
