any diff. with Used or New springs?
i see a couple of people selling their eibach springs, any downfall in buying a used springs? will the car still need to get use to the spring and then do the alignment after a couple of weeks?
Cycle Savant
Well, used springs do not need to be "broken in," so you can get a wheel alignment immediately. I doubt that the IS it came from will have a significant difference in body weight, unless if the interior was gutted, or if it was fully loaded with max weight capacities at almost all times.
New springs take about two weeks to "settle." I waited two weeks to do a wheel alignment on mine.
thanks for the fact
both great springs. I'd go with the Eibachs though. Swells Lexus sells the Eibach so Lexus must approve Eibach, and also Eibach made the TRD GS400 lowering springs. I'd go with the Eibach
Used springs would be fine, but they will still have to settle in just like a new spring. The settling time has to do with the rubber that the springs are perched on. If you get an alignment before they are fully settled, then you'll really need to get another alignment once they do.
agree! install the springs and drive the car for a week or two then go in for the alignment and you should be fine.
post pics after you are done
