L-Tuned spring/shock question
I have the L-Tuned springs and shocks installed, and i probably had it for about 3 years, close to 40K...how much milllage life does these have? Can the factory shocks work with the L-tuned springs?
Thank you.
Thank you.
i believe i recall they should last about 50k, depending upon driver and habits. next time your car is on the rack, check for any shock leaks.
if you're worried about your shocks going out, just get kyb's for l-tuned springs since those dont lower too much. they should work out just fine.
i have 65k on my l-tuned setup, mostly spirited highway.
no leaks, still a solid return.
not sure how much longer they'll last, but i plan to replace in the next 10k.
whitels
Suspension and Brakes
09-11-03 05:03 AM
