tanabe nf210 w kyb gr2
Old 12-16-07 | 07:32 AM
phillygs3's Avatar
phillygs3
Default tanabe nf210 w kyb gr2
I just ordered tanabe nf210 springs and kyb gr2 struts for my 300 i was just wondering should i have an alignment done? and i took my 20" wheels off for the winter i have my factory 16"s on for now does it matter which wheels i have on when they do the alignment? thanks for your help pics would be apreciated with this setup
Old 12-16-07 | 09:16 AM
toeb's Avatar
toeb
i shouldnt matter on witch tires you have on there. all in all your aftermarket wheels should be real close to the same O.D. as the stock. i allways have mine realigned with the stockies on.
Old 12-16-07 | 05:46 PM
4ntvings's Avatar
4ntvings
20's i believe have an overall larger diameter than oem 16's. up to you, but wait about 1-2 weeks before getting alignment.
Old 12-16-07 | 06:35 PM
SUPRAboy80's Avatar
SUPRAboy80
Default time for suspension to settle
yeah you need time for the suspension to settle...
Old 12-16-07 | 08:46 PM
VNN326's Avatar
VNN326
i needed to get mine done. i just went to firestone and got a lifetime warrenty on it. for 170!
Old 12-16-07 | 10:14 PM
GS FONZy's Avatar
GS FONZy
Not always the case, stock 16s are about 25.7" and 17s are 25.3" to where the most common tire on a 20" is a 245/35/20 with a diameter of around 26.7"
An alignment should always be done after any suspension work. The car will only settle about a 1/16 to maybe 1/8. That is not enough to change camber after alignment. You should get an alignment asap to correct any changes in caster and toe, which are the major cause of uneven tire wear.
Old 12-16-07 | 11:13 PM
4ntvings's Avatar
4ntvings
my rear settled bout 1/4" more than a week after install.
my mechanic is always eyeing my caster/toe to get as close to spec.
Old 12-17-07 | 01:49 PM
Wheel Boy's Avatar
Wheel Boy
What he said.
8jml8
01-18-16 12:09 PM
sungzilla
Suspension
23
12-02-14 06:52 PM
gotmpower
Suspension
15
06-28-13 08:06 PM
Sheehan1p
08-26-11 10:03 AM
teejnut
Performance
14
06-01-06 04:42 AM
Quick Reply: tanabe nf210 w kyb gr2
