caliper touching rotor
I have a 98 gs400 and when turning right or left Hard turns only
the caliper seems to be scraping the rotor... i havent checked the brake pads but what could be causing this??
also its only at the very top of the rotor probably about 10mm of the top of the rotor
will i need a new rotor also now?
any ideas would be appreciated
Wheel bearing. The ball joint should not cause this right? The only thing that should move the rotor with respect to the caliper is the wheel bearing.
have I thought about this wrong?
