I was convinced until I started reading...
I am looking into buying springs to make the gap on my IS cleaner.
I was convinced on the Eibach Pro-Kit, but I read a few threads about how the wheels tilt in a little, which creates faster tire wear. I do not want to go through tires every 5k miles etc... Is there any way to prevent this?
Any recommendations?
Any sort of spring other then oem will cause slight camber effects.
Unless you change out the struts too.
I dont know much about the 2IS, but are there any coilovers out there for the 2IS? Just curious...
The Eibach pro-kit should cause the LEAST amount of negative camber out of almost all the springs for the IS250AWD. The drop it has is only slight compared to the Road Magnets and some others. I will be installing the Eibach Pro-kit hopefully this week and then after 2 days it will be put on the alignment machine so I can tell you EXACTLY how much the rear camber is off. I doubt the negative camber from the Eibachs is that bad considering that the drop is moderate.
The negative camber created from lowering the car is not enough to burn through a set of tires that fast. True there are no camber kits out there at the moment, but that's because with most lowering springs the camber is within factory specs. What causes all that inside tire wear is the toe being out of spec- either toe in or toe out. So long as you get an alignment after installing the springs the tires should last just as long as they would on the factory springs.
Question to everyone who installed prokit..
Have you meassure gap on Left front and Right front? Is that same on yous?
Mine's seem like uneven drivers/passenger side...drivers side has less gap than passengers side (more drop on drivers side?). I do not do alignment yet..but
Yes that is the disadvantage of coils instead of coilovers. The IS is heavier on the driver side and will cause it to sit lower approx. 3/8 inches. The factory springs do the same thing, it is just harder to notice since it is sitting higher. That is why I got coilover overs, I actually have the driver side to full turns higher than the passenger side to make it sit dead level from corner to corner. I am obsessive compulsive, but I measure it once a month to make sure it still sits DEAD level.
But this is a reason to go with coilovers if you're **** about the ride height and want to make it perfectly even all around. My car is actually corner balanced so with me out of the car the DS is actually higher then the PS, but sits pretty evenly once I sit in the car.
Yeah!
Suspension and Brakes
10-05-07 12:15 AM
