tt supra front brakes conversion
Old 01-20-08, 04:08 PM
chienchien
chienchien's Avatar
Default tt supra front brakes conversion
my front stock 01 gs430 brake pads are wearing down can someone please tell me what year supra tt brakes will fit my car? and can i just use the original gs brake line ? thanks
Old 01-21-08, 01:35 AM
GSteg
GSteg's Avatar
OEM brake line will be fine.
There are LOTS of information out there. The search function does wonder.
Old 01-21-08, 08:34 AM
corkycal
corkycal's Avatar
make sure you find some wheels that will fit under the TT setup. those calipers are huge so finding wheels to fit may be a problem.
Old 01-21-08, 05:53 PM
chienchien
chienchien's Avatar
thanks i got the new oem 18 gs wheels and planning to run a 15mm hub adapter that should clear it
Old 01-21-08, 06:08 PM
rominl
exclusive matchup
rominl's Avatar
that should be more than enough (maybe too much)
Old 01-21-08, 10:16 PM
jesod
jesod's Avatar
I've got some brand new from toyota supra Front calipers, new d/s rotors and brand new Hawk pads. Cost me about 1000. I'll sell for 800 plus ship, if you're interested.
Old 01-22-08, 09:39 AM
chienchien
chienchien's Avatar
thanks for the offer i work for acura so i get discount at toyota which is next door. anyone think with the 15mm spacer im gonna be rubbing the fender ?
Old 01-22-08, 10:15 AM
GSoup
GSoup's Avatar
That all depends on the offset of the wheel your going to be running.
Old 01-22-08, 11:16 AM
excluesive
excluesive's Avatar
i should do this upgrade soon as well. hmmmm
Old 01-22-08, 01:16 PM
jesod
jesod's Avatar
Still don't think you can get all this stuff for what I offered. I would find out first. I've got some hook-ups too, and 1000 is about what I got everything for Let me know if you have any install ??? Definitely a great upgrade.
Old 01-22-08, 02:28 PM
chienchien
chienchien's Avatar
im running on stock 06 gs430 wheels the 18 inch one hope it doesnt rub my fender with the 15mm spacer
Old 01-22-08, 05:46 PM
GS FONZy
GS FONZy's Avatar
your hook up is not that good, Carson has the same set up for under a grand.
Old 01-23-08, 12:01 AM
Lettuce
Lettuce's Avatar
Are the Supra TT break rotors larger than the GS oem's????? If so, by how much?
Old 01-23-08, 01:11 AM
Caoboy
Caoboy's Avatar
supra TT rotors are 13.25" in diameter i believe, and stocks are like 12.1"? something like that.
Old 01-23-08, 09:22 AM
rominl
exclusive matchup
rominl's Avatar
i thought tt is 12.7" rotors. could be wrong, been too long
Quick Reply: tt supra front brakes conversion
