how to change rear brake pad on 99' gs3 SEARCH ALREADY
does anyone ever replace rear brake pad on this car b4? the caliper look a little different from the front. where is the bolt to take the caliper off? anyone has any picture on how to change it, i would appreciate it thanks
the rear is pretty hard, from what i remember i removed the caliper( should be 2 bolts holding it), but i dont remember if you can just remove the middle pin that holds the pads in place.
ok i just checked up on alldata. it does say you can just take out the shim, and then the pin in the middle which is holding the pads. and then you use a flat bar and push the caliper piston in.
sorry i dont have pictures, alldata wont let me copy
deception if you want to copy pictures off a website
just find the image on the site
click on the "Prt Scr" button on the top right of your keyboard
open up paint
right click "paste" save onto desktop
then upload picture onto www.tinypic.com
have fun stealing pictures hahah
open up paint
Here you go guys.
![](http://img.photobucket.com/albums/v431/davi99/caliper%20diy/caliper4.jpg)
![](http://img.photobucket.com/albums/v431/davi99/caliper%20diy/caliper2.jpg)
Remove anti-squel spring and pad guide pin
a. raise the "B" portion with hand, push up the "A" portion and disengage the anti-squel spring from caliper
b. remove the anti-squeal spring.
c. remove the clip and pad guide pin
Remove pads and anti-squeal shim
a. remove the 2 pads.
b. remove the 4 anti-squeal shims from each pad ( or you can use the new ones from the new pads, if they come with it)
![](http://img.photobucket.com/albums/v431/davi99/caliper%20diy/caliper3.jpg)
Press in the piston with a monkey wrench handle or equivalent.
Install new pads
reinstallation should be reverse direction as removal
Hope this helps everyone for now. let me know if i am missing some info
Install new pads
wow, thanks a lot "deception". i have a question on how to remove the clip and pad guide pin. where is the pad guide pin located? is it outside or inside of the rotor. sorry for all these but it's my first time and i want it to be done correctly.thanks
let referr to this picture http://img.photobucket.com/albums/v4...y/caliper2.jpg
you would press on "A" and should be able to pull the pin out. if not over time it should be rusted or due to heat it will get stuck. so you might want to get like a small screw driver and push it out
what do you mean "is it outside or inside of the rotor."
so I raise B and push up A to get the clip out, then i pull the pin out and that will let me remove the pad? there is no bolt or anything to get the pin out? how many pin does it has?
no no no your gettingthis all wrong.
![](http://img.photobucket.com/albums/v431/davi99/caliper2.jpg)
remove the anti squealing spring first. and then you remove the pad guide pin. if you dont do this step you cant remove the guide pin and pads.
it should be the same step:
a. raise the "B" portion with hand, push up the "A" portion and disengage the anti-squel spring from caliper this will help unlock/disengage the anti-squealing spring/clip
c. remove the spring/clip and pad guide pin
d. then remove pads out of caliper
