is350 brakes
is350 brakes
for those with 250's and upgraded to the 350 brakes. do u guys know if u can put the old 250 front brakes in the rear? i figuar its kinda a waste of u dont use them . also any good brands make slotted/drilled roters? i like the look
Well..I don't think you can because you'd need custom brackets first of all to mount the calipers in the rear..then you'd have to worry about other clearances in the rear when you slap a bigger rotor back there.
Plus the front rotors have a top hat area and the rears do not, just like the rears are not vented like the fronts. It wouldn't work man..and if it did, then you spent too much money to make it work. Then you have issues w/ brake bias, your master cylinder, etc. Not worth it..
