Bouncy ride NF210's stock shocks
I had NF210's installed on stock shocks this weekend. The ride is pretty comfortable and not much different than stock except for a little bounce. I notice it at lower speeds for example in a slightly uneven parking lot. My previous Acura Legend had a similar issue but it had 150k miles . I definitly took notice that the GS400 didn't do this stock but did when the springs were installed it was noticible.
My question is this: Is this "bounce" due to the nature of the springs or do the shocks need to be replaced? The GS400 is a 99 with 70k miles.
There was no evidence of a shock problem with stock springs and no evidence that they needed to be replaced at the time of spring install. I want to keep as close to factory ride as possible. The bounce I am speaking not something that is really harsh or present during most normal driving. It is just something that is different after spring install. If I can get a little closer to the factory ride with different shocks then I open for recomendations.
Guest
Posts: n/a
Check your air pressure. You might have way to much air in the tires.
Also check out your local Lexus club, www.seloc.net in Atlanta!
Oakley IS
Suspension and Brakes
04-26-09 08:15 PM
