RCA's with springs
RCA's with springs
It seems RCA's have been installed on cars with coilovers, but has anyone tried front RCA's with springs? Specifically L-Tuned Springs? Any measurable improvement in front-end camber? My goal is to add positive front end camber (additional lowering is not a priority). Any feedback is greatly appreciated.
Cheers,
DJC
Cheers,
DJC
I have l-tuned and will be installing my RCA when I get off my lazy butt (actually i'm pretty busy )
Your camber will change ever so slightly with springs/RCA combo. The coilover guys will be able to take the RCA into advantage by being able to adjust back to their original height after installing the RCA. Unfortunately, us spring guys wont be able to do that for obvious reasons.
In my case, it actually works perfectly believe it or not. The L-tuned springs lowers the car 1" all around, but the front gap is larger than the rear from the factory. So my RCA will actually give me even gaps all around
Many thanks,
DJC
Where did you get them...?
Thanks for your reply and the picture. Was the 0.5 degree gain in camber enough to bring your front-end camber back in OEM spec? Do you have any full side pictures of your car to show how much lower the front is than the back? Finally, where did you purchase your RCA'S?
Many thanks,
DJC
Many thanks,
DJC
daltexlex
11-29-07 12:41 PM
koreanpers
Suspension and Brakes
10-06-03 08:58 PM
