Trac light + Check engine light on?
Hi there guys, I just recently bought a 95 Sc300. A problem i have noticed is the traction Control Light automatically flashes "off" then the Check engine light turns on, or vice versa. If I reset the ecu, it goes away for a little while a come back obviously. What is the cause of this? O2 sensor?
To make it short:
Traction Control lights "off" then Check engine light turns "on". ?
To make it short:
I have the same problem, but mine is that when first started the switch would make a clicking noise when depressing the brake pedal short distance, then the track light and check eng light would appear , still persists , but everything seems normal as far as braking goes
Jasoneo5
03-06-04 02:55 PM
Lextreme
01-25-03 03:00 PM
