TSIB refussal for '07 350
#46
MUST replace rotors? Tell them you want to see the measurements on each of them. Minimum thickness for the front is 27.0mm and they start at 30.0mm. I would only consider replacing the discs if you have less than 27.0mm. The engineers have done a lot of calculations to determine acceptable limits for service life, so I would never, ever, replace a disc unless it is below the minimum thickness.
At 3/32, you still have 11.8% of the life of the pads left. At your current wear rate, that's 33750 miles, or more than 10% unused service life left. Sorry, but it's not time to replace them yet. You could go to the next service at 35k and be fine.
As for the rotors, they said it's unsafe to resurface or reuse the rotors (regardless of how much the rotors are "worn") once they take them off. If they are replacing the pads, they said they must replace the rotors with new ones, which cost $291 for one side and $252 for the other. Is that reasonable??
#47
Thanks lobuxracer! They said I probably have 2-3 thousand miles left in the pads, but it sounds like I may have even more than that.
You mean they're saying you MUST replace your rotors anytime you replace your pads?
No, that's not even close to reasonable. It's an outright lie.
#48
I think JavyLSU did a DIY thread on it.
#49
Tech Info Resource
They're telling you it is unsafe to resurface a disc? Why does the Factory Service Manual tell the tech to grind the disc if it is not flat if resurfacing is unsafe?
#50
When I called back to get more information about why the rotors need to replaced, here's what my service adviser told me:
He offered to show me the lip in the rotor when I go in to pick up my car, but I don't know nearly enough about brakes to tell whether the lip is bad enough that they can't be resurfaced or "cut". I could take my car to another Lexus dealer and get a 2nd or 3rd opinion. Or I could use a non-Lexus shop, if I could find a good one in my area (No. VA).
I don't think I'm up to replacing my own brakes, but I'll take a look at Javy's DIY thread and see how difficult it looks:
https://www.clublexus.com/forums/sho...d.php?t=276736
On some high-performance cars, such as the IS 350 and most BMWs, the rotors are made of a softer compound that gets a really bad lip worn in to it over the life of the brake pads. This lip is bad enough that the rotor cannot be resurfaced or rotated. They call the rotors for the IS 350 "throw-away brakes" because they must be replaced when the brake pads are replaced.
#51
Tech Info Resource
And claiming the rotors are soft is the biggest bunch of crap I've heard in a long time. They're gray cast iron. It doesn't come in different hardness ratings, and it hardens the first time you get it hot anyway. I'm really amazed at how some of these dealers are ripping people off.
#53
I'm no mechanic, but from reading the Factory Service Manual page you attached, it looks like the lip could be so bad on the rotor that replacing them *completely* with new rotors is the only option:
If the disc thickness is less than the minimum, replace the disc.
I called the "Lexus Customer Satisfaction" number 5 days ago, and they just called back to tell me they are starting to look into this, and will be in contact with the dealer and me over the next 5 business days. I have already started to pursue other dealerships in the area, both to resolve this problem and to take my car to for future services.
#55
#56
Tech Info Resource
Lobuxracer,
So is it possible that the rotor can't be rotated, resurfaced, or ground, if the thickness that remains on my rotor is less than a certain amount (what is this amount, btw)? I asked my service advisor how much thickness remains in my rotors, and he couldn't tell me. (He said "we don't even measure the thickness of the rotor if it needs to be replaced".)
If they didn't measure the thickness, they don't have a clue whether the disc needs to be replaced or not. The only thing they are concerned about is lightening your wallet. I'd have a field day with this guy, and I'd make sure corporate knows this dealer is ignoring the factory service manual.
#57
i love it when dealership tell you when you need stuff and when you don't need stuff like ur an idiot that doesn't know jack.
they try to act like their taking care of you but they're really not by not listening to you.
I wish there were more local shops that knew how to do maintenance on high end cars that anyone can go to with any vehicle instead of our dealerships.
I'm also starting to think about doing things at home but I'm kinda lazy. I work 5 AM - 4 PM at a warehouse
