How to Adjust ride hight on coilovers?
Old 02-07-08, 03:18 PM
97-SC300
97-SC300's Avatar
Default How to Adjust ride hight on coilovers?
i am trying to figure out how to adjust the hight on coilovers.
i bought cusco coilovers and have not installed them yet, i tryed to adjust them off teh car to see how it works but i am not sure what to turn lol. any help wuld be great.
Attached Thumbnails How to Adjust ride hight on coilovers?-cusco_z2e_wrx.jpg
Old 02-07-08, 03:35 PM
pnyboy27
pnyboy27's Avatar
i have megans on mine..so mine might not be exactly the same as your setup..but what i have to do is loosen the top "nut" thing by the spring, and the bottom one a bit, then turn the top one clockwise to lower it..then tighten it back up after getting the right height..it shouldnt be that difficult, just time consuming depending on how low you plan to go and how high their set up at right now
Old 02-07-08, 03:43 PM
97-SC300
97-SC300's Avatar
i think the top on on these is for spring preload. i dont think that gets loosened, maybe i am wrong.
Old 02-07-08, 03:44 PM
AutoCoutureSC
AutoCoutureSC's Avatar
from that pic, it's the stainless steel lock nut and seat
Old 02-07-08, 03:48 PM
97-SC300
97-SC300's Avatar
after i loosen the stainless steel lock nut and seat what then?
Old 02-07-08, 03:50 PM
AutoCoutureSC
you will see the springs compress / de-compress. you have to pull them out of the box and experiment. then when you get the height you want, you take the two nuts, and turn them towards each other to "lock" them into place so they don't move anymore... it's pretty much self explanatory
Old 02-07-08, 03:53 PM
97-SC300
97-SC300's Avatar
then what is the lower case lock nut for?
Old 02-07-08, 03:55 PM
AutoCoutureSC
i have TEIN CS, so the diagram is diff than what is shown above.
that stainless steel lock nut case... it doesn't look like you need to move it. only those lock nut and seat from above. They look like two washers.
Old 02-07-08, 03:56 PM
AutoCoutureSC
they should give you a special tool to move those two pieces. If not, you can't move them by hand.
Old 02-07-08, 03:58 PM
97-SC300
97-SC300's Avatar
there is a tool. but if you look at the pic it says that the lower case nut is for hight adjustment. iand i dont see how it would be since after you install it on the car how would you lower it with the lower case nut.
97-SC300
97-SC300's Avatar
all the diagrams are in japaneese that came with teh coilvoers lol so its no help.
Old 02-07-08, 03:59 PM
AutoCoutureSC
that setup is different than mine. maybe that lock nut locks those two lock nut and lower seat into place.
in all seriousness, you gotta pull them out and experiment if you're unsure. you really need someone to show you, or you do it yourself. I doubt you'll break it
Old 02-07-08, 04:31 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
You should be able to turn the lower seat lock, it looks similar in design to my old Kei-Office coil overs (however they have seized so I can only move the seat lock and not the lower strut section).
Old 02-07-08, 04:45 PM
97-SC300
97-SC300's Avatar
here is what came with them if nyone can figure it out....
Old 02-07-08, 06:19 PM
pmpdaddyt
pmpdaddyt's Avatar
jack up the car. thats what i had to do with mine, and have either really skinny arms or take off the wheel
Quick Reply: How to Adjust ride hight on coilovers?
