Thud/Clank sound coming from brakes
I am hearing this thud/clank sound coming from my brakes. This sound occurs occasionally when releasing the brakes after putting the car in gear.
For example: Pressing down the brake, then putting it into reverse then letting go of the brake = occasional thud/clank sound. This also occurs when I release the brake after going from reverse to drive. At first I thought it was the transmisson, but after further investigation, it clearly has something to do with the brakes, calipers, etc. Not sure if anyone else has noticed this.
i have the same problem...the noise seems to be coming from the rear passenger wheel. it started out as you described and has gotten progressively worst (as in it happens all the time now). need to find time to take it in to dealership...
I have the same problem but the dealer can't find the problem. However, the service manager told me it was normal having to do with the 350's brakes, although I have a hard time believing he telling the truth.
i am having the same problem...i was told by the service tech that , sound is coming from brake pad shifting and i told him that it is absolutely not normal and then he tells me there is nothing they can do about it, next time i am going to speak to their service manager to see if they could do something!!
Okay I just took my car in to get the cold start rattle issue (TSB) taken care of. I also mentioned the thud/clanking sound coming from the brakes... we'll see what happens. I will definitely keep you guys posted.
UPDATE: Just got the car back. Lindsay Lexus told me there was nothing wrong with my breaks, pads, calipers or rotors. It appears that we are destined to live with this noise.
hey guys, i finally took my car in last night regarding the brake noise. i drove w/ the service foreman and upon confirmation of the noise, he said it was normal. he said that he gets this question at least once a week and has tried a few things, but unable to eliminate the problem. i'll try taking it to another dealership to see if they can help me out.
Stop wasting your time with this problem. This was the Service factor given to the break pads for heat expansion. When cold you will get a small movement. You don't want your pads to be solid to the calipers, they will crack. What your hearing is it tap the metal on each side. Look at the pic.
fixed
took my car to lexus mission viejo and they confirmed noise was from the front brakes. i took the opportunity to try out the new low dust pads and problem is solved. no more clicking noise.
i noticed it happened _after_ the low dust brake's from the GS line were installed. it also seemed to happen more consistently the more i shifted from D or R into N with the breaks firmly applied.
Exactly !
I looked at everything in the well well, and nothing was loose when I got the wheel in the air. I am not going to worry about it. The car stops on a dime. Heck I don't mind cleaning the brake dust every other time I drive it.
gadgetman1
Hybrid Technology
13
03-23-19 10:35 AM
