K-Sport Kontrol Pro Damper System vs Tein Comfort Sport Coilovers
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs.The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
VS
Designed and developed with the sophisticated driver in mind, the Comfort Sport Damper provides increased handling and a more stylish appearance while retaining a smooth civilized ride.
New Technology: Features Tein's latest technological innovation, the Micro Speed Valve (M.S.V.), improves overall traction and steering response by precisely controlling the internal flow of oil.
Design: The smooth, sleek black shell case is coated with a special fluorocarbon resin for superior resistance to corrosion. Gold alumite spring seats and locks distinguish the Comfort Sport dampers from competitors and ensure a simple, hassle-free adjustment, every time.
Development: By using popular sized wheels and tires to develop the Comfort Sport damper, Tein is able to accurately determine the optimum spring rates and damping to achieve a perfect balance between comfort and performance.
Which one is better choice for nice comfortable ride? considering that K-Sport is about $600.00 less then the Tein CS.
Thanks for help.
Neil
VS
Thanks for help.
Neil
b2designs
Club Lexus Vendor Marketplace
45
12-01-11 06:45 PM
Elite Autosport
01-26-10 07:34 PM
