Help w/ Camber Kits for IS 350 w/ mod Suspension
I'm looking for some help...I've installed Tein CS Coilovers on my 07 IS 350 and dropped it as low as it will go in the front...about 2.5 inches... with stock wheels and tires. I can't adjust the camber enough...do I need a camber kit...if so where can I purchase one? Any help would be appreciated... Thanks!
No camber kits are available as of yet. If you are running a little in the negative though it isn't that bad. Just make sure your Toe and Caster are set correctly and wear will be minimal. I have had no wear issues with my tires on the same setup as you.
Tech Info Resource
OP - Read this thread.
Any new camber related threads will be referred to this thread and locked if they continue to ask the same questions again.
SprtDesign
09-09-13 04:06 AM
