max camber?
That question is so vague its not even funny.
What do you mean what is the range? I am assuming yo are dropped and have some large rims. That should help with answering your question.
Max I have been able to get from stock alignment on Tein CS as low as they go on 19's is 1 degree of negative camber. Can't seem to get it any closer.
i just wanted to check how much negative camber i can get so i can try to fit some wider/lower offset wheels under the fenders. i guess i will just go play with it on a alignment machine and find out. thanks.
You can get pretty negative man.
Not sure on the exact number but there are a few people that are SLAMMED on some crazy negative camber in here. I would have to say whatever you are looking to do it probably can be done with the stock camber alignment equipment.
