My gixxer_drew Bilstein Hypercoil Review
#211
Noise/Clunking
Did anyone else experience clunking in the front with their setup?
I'm on the 600/8" and 325/10" setup and I get a clunking noise coming from the fronts only. I didn't notice this on the Supra TT wheels, but after a road trip last weekend on the 19's and driving it around this week, there's definitely noise unbecoming of a Lexus. It only happens on sharp bumps.
I'm assuming it's the Bilstein top hat hitting the shock top, but I won't know for sure until I take a better look this weekend. Any ideas?
PS: The car has ~81K miles, so I would think the bushings are in better shape than most...
2009-08-12 Edit: One of the endlink nuts had come loose. Tightened it up and bye bye clunking!!!
#212
mounts
found something see what you guys think .
http://www.daymotorsports.com/produc...S-FOR-BILSTEIN
#215
Time for me to join the gixxer drew club.
Energy suspension bump stops in the upper perch and by itself on the right with bilstein sleeves in the middle
Hypercoil spring rates 600 lbs front 325 lbs rear
And of course the bilstein shocks.
If people are having a hard time fitting on the sleeves. Make sure that the taper you are trying to cut out is definately gone. I had to slightly trim another thread or two on the sleeves because they would not fit unless the bottom inside of the sleeve was totally flat.
#216
Any suggestions on how to adapt this setup to a 1995 ls400? My front axle weight is 2060lbs and rear 1720lbs with a full tank of gas. Believe it or not that is about the same as a sc400. I think my front/rear weight distribution is a little better than an sc400, but probably not enough of a difference to affect front/rear spring rates.
#218
400lb/225lb Still firmer than stock right?
Here's an example of what I'm looking for. I've driven a stock bmw 325i 1999, and a stock bmw 325ci 1999. The ci is the inclusive sport package that includes factory lowered ride height, and a slightly stiffer ride than 325i. I actually love the ci's ride quality and was wondering will just going 400lb front and 225lb rear on my 98 sc400 will give me a similar ride quality than the 325ci? Does anyone know? Those numbers are still higher than the stock sc400 spring rates right? As a matter fact, they are even higher than Tanabe springs.
#219
I just want to make sure I have everything before I place my order(s)
Bilstein Shocks - Set of 4 F&R AK1242,AK1243 from shox.com
COIL OVER KIT, 5" SLEEVE, 2" BODY from speedwaymotors.com
Do I get the 7" instead ??
Hypercoil (Front) Spring 550#/in 2.50 ID 8in length from shock-shop.com
Hypercoil (Rear) Spring 350#/in 2.50 ID 10in length from shock-shop.com
I am also looking at getting 4x Energy Suspension 4-6103 (Mustang Bump Stop)
#221
Yes. Those will work for the rear too. I bought the 5" sleeves. They work great with no cutting needed. Mine had to be placed with the tapered edge sitting on the c-clip. If I would have placed it with the other side, the sleeve would have been positioned above the body of the shock and the cap wouldn't have gone on.
Advice - don't go too low at first. Springs take a while to settle. You'll be in for a rough ride if you try to slam it to begin with. Also - go get it aligned every time you adjust it. Good luck with the UCA bolt on the front driver side...PITA. You may want to pick up some Deep Creep or PB Blaster.
#222
Sorry if this question has been asked before..
How high can you raise the GixxerDrew setup? I want to do this for my daily driver, but in the winter, I don't want the car slammed. I'd like to have a good inch at least above the tire. Is that possible going GixxerDrew?
#223
However after doing this I will advise this....leave the clips on the shocks right where they are from the box, ie they are on the lower cut in the rear and the higher cut in the front. You will have less adjustment to do in the long round that way.
#224
I did this mod a week or so ago and I added cut inner tube tire between the tophat of the Bilsteins and the stock tophat (2 double walled in front/one double walled in the rear). The result is a LOT LESS noise/vibrations/harshness (NVH) when you hit a sharp bump or a pothole. I have bad roads around here so it certainly was necessary for me.
What the inner tube does is it replicates what the rubber isolator (continues with the rubber boot on the stock shock) does for the stock suspension.
PS I am using 600lb fronts and 350lb rear
#225
It's been a long time since i got word on the gixxer setup and i always keep it in mind but was looking at the meagan coilovers but now that i see alot of sc members have the setup and speak so highly of them i may just go with the gixxer i want my suspension to be the shid but at the same time i dont want to have the teeth rattling part when going over little bumps and railroad tracks so... guy's point me in the right direction because after reading that the 500f isn't to far from stock so the 600 would be better but i didn't get to much on the rear do you think 400r will give me what i'm looking for or is it going to cause me a trip to the dentist... my car isn't going to be a track car... just a daily driver and highway puller and once in a blue moon might hit the 1/4mile!!! if anything to can send me a pm
thanks!!
thanks!!
