My gixxer_drew Bilstein Hypercoil Review
Old 05-14-08, 04:55 PM
  #46
Stupidnewb
Stupidnewb's Avatar
Well, I got them installed but the rears are SQUEAKY! I think the top mount is moving around a bit, hopefully they'll settle in. Did anyone else have this issue?
Old 05-14-08, 05:43 PM
  #47
RedPhoenix
RedPhoenix's Avatar
that weird. look at them carefully, they should not be squeaky.
Old 05-14-08, 07:04 PM
  #48
sumotime
sumotime's Avatar
Could you write out your order for parts. Specifically the part numbers from summit. I think I have the right parts and I just want to make sure before i order them..
Old 05-15-08, 06:16 AM
  #49
Stupidnewb
Stupidnewb's Avatar
You'll save money with Speedway...
Old 05-15-08, 10:16 AM
  #50
Vadim
Vadim's Avatar
Hi guys.
I Vadim from Russia to the Urals going to the Lexus SC 300-97 of engines 2JZ-GE. My SC 300-97 wheels at 17x8/9".
My goal - to travel quickly and more aggressively on public roads. Roads in Russia - this is not an American ring, and not even the American road. Coilover spring at the - before - 14k gf / mm and backwards - 10 kgf / mm are not suitable for Russian roads. After the installation of such springs - knock your teeth, jumping machine, makes reshuffling overtaking. This is bad.
Carefully read by electronic translators your theme and the theme gixxer_drew: http://www.supraforums.com/forum/sho...d.php?t=446817.
You have a bright golden head and hands. I welcome your ability to do such a complex E ngeenireng work.
I have bad English and perhaps not all, I understood from the translation of your theme, which made me machine (electronic translator).
I ask you to answer my questions:
1) Why did you apply to the SC 300 racks of Supra TT? they are shorter than stock racks for SC 300.
2) stock springs SC 300 have force: Front - 6.57 kgf / mm; Rear - 3.24 kgf / mm. What efforts have springs that you put on the rack Bilstein - Front? and Rear?
3) What (which device?, A castle?) Holds a black sleeve on the yellow rack fixings for a new spring?
4) Use your new design rack (Bilstein + new black sleeve + new spring) made the suspension on your Lexus SC 300 as:
Tein Comfort Sport: Front-10 kgf/mm, Rear-6 kgf/mm. ?
Tein Super Street: Front-14 kgf/mm, Rear-8 kgf/mm. ?
Jic-magic FLT-TA R: Front-20 kgf/mm, Rear-12 kgf/mm. ?
Thank you very much for your attention to my questions.
Good luck.
Vadim
Old 05-15-08, 04:50 PM
  #51
Stupidnewb
Stupidnewb's Avatar
Found my issue, the rear springs are rubbing slightly on the sleeve at the top end. I've only put maybe 5 miles on them and it seems to be going away quickly. It'll probably wear down the threads a bit and clearance itself, so I'm not worried. It shouldn't affect the strength of the sleeve whatsoever and I don't plan on setting the car to 4x4 any time soon, so the threads won't be missed.
Old 05-15-08, 06:38 PM
  #52
Leexus
Leexus's Avatar
@Stupidnewb
Are these the parts you have ordered?
Old 05-15-08, 06:43 PM
  #53
sumotime
sumotime's Avatar
R . P. Ordered the 10" at 300lbs and the 8" at 500lbs. The guy at speedway said the longer spring needs to be softer because of more spring to flex. I THINK !!! I am a Fishing Guide and not a mechanic , so wait for confirmation on it...Sumo
Old 05-15-08, 07:45 PM
  #54
sumotime
sumotime's Avatar
Hypercoil Springs
QTY X2 $55 ea Front: 8" x 2.5"ID 500lb/in rate (shock-shop.com)
QTY X2 $55 ea Rear 10" x 2.5"ID 250lb/in Rate (shock-shop.com)
As a Follow up..
Old 05-16-08, 01:00 AM
  #55
Stupidnewb
Stupidnewb's Avatar
That's what you want!
Old 05-19-08, 08:06 PM
  #56
RedPhoenix
RedPhoenix's Avatar
You got it. anywhere from 250 to 300 in the rear is good.
Old 05-20-08, 10:41 AM
  #57
b1ackhawk
b1ackhawk's Avatar
I notice speedwaymotors has both carrera and hypercoil, what was the rationale for going with the carrera's?
Old 05-20-08, 08:26 PM
  #58
sumotime
sumotime's Avatar
Carerra were chrome and Hyper Coils were Blue. I like the Chrome color. They are about the same price.
Old 05-23-08, 11:25 AM
  #59
b1ackhawk
b1ackhawk's Avatar
How are you going to keep them from rusting fast?
Anyone know if theres a weight difference?
I would assume chrome would be heavier
Old 05-23-08, 11:31 AM
  #60
b1ackhawk
b1ackhawk's Avatar
Originally Posted by Stupidnewb
Here you can see I've put the spring ring to the lower setting. The sleeves are mounted with the inner angled ring contacting the spring ring, as the other direction would stick out to the point that the endcaps wouldn't seat.
Here is a look at the stock mounting location vs. the lowest possible setting on the sleeve. I don't plan on dropping more than 1.5" or so, so this is more than enough. The 7" sleeves are probably a better option if dropping 3"+.
So whats the actual drop from stock to the lowest setting here?
BTW, thanks for the info, great setup!
Quick Reply: My gixxer_drew Bilstein Hypercoil Review
