Front Driver's Side Noise
So I’ve got a cluncking/rubbing sound coming from the front driver’s side that I only hear when I go over a significant bump in the road. It kind of sounds like the wheel is momentarily rubbing against a splash guard, but I looked and didn’t see any signs of a loose splash guard or any spot where the wheel was rubbing. The sound is intermitent, but I hear it every time I go over a speed bump.
I’ve tightened down all the suspension bolts and that didn’t help.
I did a seach and others with a similar problem needed their strut mount replaced. So I took apart the strut, but the mount is in great condition.
Tie rods, lower ball joint, castor arm bushings, upper control arm bushings, sway bar bushings, steering rack bushings, and brake shim kit have all been recently replaced.
Any ideas what it could be? Wheel bearing?
if everything from the above has been replaced, it sounds like it could be your wheel bearing...but, check this out, jack up ur car and see if you have any play in your wheels, if u do then it's most likely the wheel bearings.
I just ordered some Timken wheel bearings for my front wheels before I replaced my bj's and tie rod ends, I initially thought my wheel bearings needed replacement but apparantly they dont. So, if you need, i got the parts. Plus, Timken is a reputable brand for wheel bearings, there's a thread on CL on them.
Thanks tommyjaix. I checked the wheel play. I pulled/pushed the wheel holding it at 12 and 6 and there's no play. The wheel is solid.
The sound is intermitent. But I consistently hear it when I go over speed bumps.
Any other ideas?
Any other ideas?
hmmm...check ur brake clearance, does it sound like ur brakes rubbing against the rotor? I mean, u obviously mustve step on ur brakes while u go over bumps and as u do that, the sound u hear might be ur brakes just rubbing against the rotor. I get the same sound while im releasing my brakes, the clunking/rubbing noise and its pretty loud to, i think its normal, since I have those EBC green stuff brakepads and they're pretty sticky
That's a good thought. I doesn't happen when I break the only thing that seems to cause it is when I go over a bump or dip in the road regardless of whether I'm braking, coasting or accelerating. But maybe....But wouldn't I hear it from both sides? I'll check out the clearance.
I was driving over speed bumps yesterday and it sounds like a noise that the spring could make when it's being compressed. But I checked out the spring when I was looking at the strut mount and it didn't seem like there was anything out of the ordinary.
It's odd too because it's not consistent. I hear it every day, but some days I hear it more than others.
UPDATE: I went to a Lexus shop. They said the lube on the Daizen upper control arm bushings has probably worn out and is causing the sound. The owner said he had a 2nd gen GS and had to lube his Daizen bushings from time to time. I installed them, so I know I lubed them up real good. He said sometimes the lube wears out no matter how much you apply. I'll update once I lube the bushings.
clunking rubbin sound........? does the rubbin sound metallic? i want to know this one to!!!! on my driver side too. Never could figgure it out, tightened everything, swapped suspension everything, etc......... cept the wheel bearing thats why i thought mabe it could have been the wheel bearing, but my wheel doesn't have play either when its being wiggled. I also have daizens bushings and it doesn't happen every bump? sometimes it doesn't even happen. The only reason why it bothers me because when i go over a series of bumps it sounds like the driver side is about to fall apart when i have the radio off.
i have this problem too i just changed my brake pads and rotors, i hear this noise rubbing noise when i slowly release take my foot off the brakes and sometimes when im coming to a stop slowly...the lexus Mechanic said its a normal thing you hear it inside the car but outside u really cant hear it..any solutions?
5% Club. Killing it!!!
Thanks
Tony
Thanks
Tony
Hi guys!
Hello fro Latvia!
The same situation the same disgusting NOISE!
There was proposal from my dealer to change ball joints, struts and etc., but ... you can imagine a total cost for that "overhauling". Most stupidest is that that (in my fall) don't help at all!
After long seeking I found that NOISE gone 100% when I changed ... (its really unbelievable!!!) ... just front BRAKING PADS! I put there NONoriginal and noise is gone! Thats all!
Good luck!
Hello fro Latvia!
Good luck!
sneakyimp
10-19-18 09:54 AM
