LOLL How the ****^^^ god u make my **** look like a jeep
haha the entire inside of that fender is pretty much gutted except a 8x8 sqaure of fenders liner behind the fog light.
this is how you drive that low... btw this is at a shop my dad works at, i did most of the work on the inside of the fenders to make it work. and had help with the bondo and clean up
see how much clearance i gained inside. i fully removed the fender tab
this is the rear after my exhaust ripped the bumper off. see how much clearance in the rear you have tucking rim. not much what so ever. the rims used to hit the fender when on the freeway because of bigger dips.
i hope you didnt shave the front... and in the rear there will be a point if they are shaved where the inner fender will seperate from the outter fender. and itll look horrible and its a pain in the **** to shape trust me i went through that already. it sucked trying to get a final shape after it splits. but you have about 10mm before itll release.
^^^ so effin sick how does your fender well look ?? if its still there of course. gotta get those rear tires flipped bro.
My fender well up front is a bit chewed up but not to bad. My front bumper tab on the passenger side is no longer there but oh well!! It looks sick though. Slight rubbing on the sidewall of the rear tires(gotta trim a bit more). I'll flip tires soon.
cut the tabs off son! itll give you way more room trust me!!
