Caliper is stuck
So I just found out that my caliper is stuck on the right side...is that the reason my car has bad alignment on the freeway? Also, I don't know if it's because I didn't change my bushings, but my car makes weird noises when I turn the wheel on a stop, and when I brake.
Thanks for your help.
Yeah they said that the piston is seized...and it ate through my rotors...is that a bad thing?
And I don't know if that caused it, but now my bushings are going out, ball joint is creaking CRAZY! so i have replace everything now.
Hey, sorry I was supposed to send money order to someone for the calipers but I accidently deleted my inbox. Whoever it was, can you PM your address again? Thanks!
