sway bar links help!
Old 03-12-08, 02:17 AM
hurricane
hurricane's Avatar
Default sway bar links help!
gettin my daizen sway bars put on my car ... shop told me i should replace the car with new front and rear sway bar links or car will prob make a ton of noise .. got a price of 3oo$ for all from sewell lexus>! expensive! do i really need to replace these? should just buy the tom 6 link for the back and any aftermarket options for the front? thanks guys
Old 03-12-08, 02:18 AM
hurricane
hurricane's Avatar
wat i really was askin .. is if the sway bar links must be replaced.. what are the good aftermarket choices .. front and rear! toms only sells rear correct ?
Old 03-12-08, 02:59 AM
JeffTsai
JeffTsai's Avatar
Sway bar link are not the same as the chassis links. In short there are no aftermarket higher performance sway bar links for our cars.
Old 03-12-08, 03:16 AM
hurricane
hurricane's Avatar
thats alot bro .. ok so 1 last question .. is it needed to change these sway bar links when installing after market sway bars?
Old 03-12-08, 08:03 AM
JeffTsai
JeffTsai's Avatar
The links only need to be changed if they're worn out. How many miles does your car have? Usually if there are no rips or tears in the link boots then you're fine.
Old 03-12-08, 08:26 AM
hurricane
hurricane's Avatar
like 130,000 miles bro
Old 03-12-08, 08:41 AM
GSteg
GSteg's Avatar
No need to replace unless they're worn out. I've installed a few sets on GS with over 100k miles and the links have no play in it.
Old 03-12-08, 10:54 AM
hurricane
hurricane's Avatar
thanks for the help guys
Old 10-24-08, 02:14 PM
hobojoe
hobojoe's Avatar
hey guys im in the process of doing my 91 ls4 sway bar and in the process of removing the links from the old bar i had a bit of grease squirt out..... is this going to trash the link or you guys think i should be fine?
Old 10-24-08, 02:21 PM
GSteg
GSteg's Avatar
How much came out?
You should be fine unless you're severely out of grease.
Old 10-24-08, 02:24 PM
hobojoe
hobojoe's Avatar
ummm, i wouldnt say alot but an ok ammt did, im assuming from research i could still drive it with grease missing and i might just run the risk of the link going bad and having to replace it correct?
Old 10-24-08, 02:30 PM
GSteg
GSteg's Avatar
Yup. I think you'll be fine though. Some of my grease came out and til this day i'm not dead
Old 10-24-08, 02:32 PM
hobojoe
hobojoe's Avatar
haha ok good yea i did it and right as i clamped on the link and loosed it squirt... i was like Craappp. maybe ill just order 2 new rear links this weekend justt incase.
Old 10-24-08, 02:36 PM
GSteg
GSteg's Avatar
If you want, you can get some lithium grease (automotive section, made for cv joints and stuff) and squirt some back in.
Old 10-24-08, 02:39 PM
hobojoe
hobojoe's Avatar
Good idea, I will try it thanks bud!
Quick Reply: sway bar links help!
