IS350 Alignment specs
I just an alignment done by lexus. The print out on states "IS350: standard suspension". I have the sport suspension.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Does anybody know if there are different specs for sport suspension vs standard suspension (for alignment)?
If so can you post the specs for the sport suspension?
The difference between standard and sport suspension is a few milimieters and slightly stiffer spring rate (I think)
The alighnment specs for both would have the same tolerences.
So, even if the tech used "standard" or "sport" he would have made adjustments to get the toe, etc., within specs according to how far in or out of adjustment your car was....
So, yes it's probably fine, but if it's really bothering you, go back to the dealership or call your service advisor to set your mind at ease.
The service advisor told me there wasn't a difference but I wanted to ask people here just to make sure they asked the techs and not just pull that out of their b... The dealership did do the alignment and the car seems to go straight. Before it pulled a little to the right. The reason I brought the car in was the passager front tire had "cupping". The discount tire told me it was due to alignment problems or suspension problems.
Lexus told me to have the alignment done first. If it was within specs it could be the suspension. If the alignment was out of the specs , it would bring me back into specs. So now they said if the problem (cupping) gets worse to bring it back and they can take a look at the suspension.
Jeremiah87
10-23-13 11:05 AM
Fizzboy7
Suspension and Brakes
11-15-10 11:40 AM
