0* rear toe?
0* rear toe?
I recently replaced the shocks with some kyb GR2's and replaced front LCA bushings and all rear bushings along with both swaybars with daizen. Swapped some good tires on it and took it to the alignment shop.
I printed this out from lance w. and gave it to the alignment shop, and everything was dead on with the exception of the rear toe. It was zeroed out at 0MM for some reason. How bad/funky will this make the car handle, and should I take it back to the shop? I didn't see the discrepancy till after I got home, but the car handles amazingly compared to before.
Anyway, how will 0 rear toe affect handling on an SC? Will it cause the rear to swing around?
Thanks
Thanks
