L-tuned ???'s
Old 03-19-08, 01:50 PM
MATEOGS
MATEOGS's Avatar
Default L-tuned ???'s
are l-tuned springs able to be put on stock struts?
Old 03-19-08, 01:52 PM
GSteg
GSteg's Avatar
Yes.............
Old 03-19-08, 01:58 PM
GSquicksilver
GSquicksilver's Avatar
but since you're going to do all the work, might as well put in new struts since the stock struts will wear out at a faster rate with lowering springs.
Old 03-19-08, 02:21 PM
4ntvings
4ntvings's Avatar
Originally Posted by GSteg
Yes.............
what he said
yes
10 char
Old 03-19-08, 02:23 PM
MATEOGS
MATEOGS's Avatar
how much will they lower the front and rear b/c im getting staggered 20"s?? how is the ride comfort compare to stock? I drive 30 miles to work each way everyday and bought a lexus for a reason.
Old 03-19-08, 02:30 PM
4ntvings
4ntvings's Avatar
l-tuned springs are fine on 20's. get a set of kyb's and you're good to go
Old 03-19-08, 02:36 PM
MATEOGS
MATEOGS's Avatar
will ride comfort still be nice.I hate hard suspensions!! all day at work im in a 2007 pos work truck with th hardest suspension and if my lexus turns out like that im gunna be pissed!!
Old 03-19-08, 02:40 PM
testing
testing's Avatar
I want to get the L-TUNED springs for my gs as well, but still stuggle with getting a KYB shock or just with the stock shock.
Old 03-19-08, 02:49 PM
ZippyGuy
ZippyGuy's Avatar
There's lots of speak to spring/shocks on the site, check the search engine it's pretty good
For a REALLY smooth ride with some drop I think the Tanabe NF (normal feel), which will give you a great drop (1.5 front, 1.0 rear) pared with Bilstein Sport shocks. You might also want to look at Eibach springs.
Old 03-19-08, 04:12 PM
testing
testing's Avatar
If we drop 1.5 " on the front, can we set the camber back to the OEM specs?
Old 03-19-08, 04:18 PM
4ntvings
4ntvings's Avatar
confused. what is there to struggle with?
Old 03-19-08, 04:57 PM
testing
testing's Avatar
Budget$$$$$$$$$
Old 03-19-08, 06:37 PM
4ntvings
4ntvings's Avatar
Budget$$$$$$$$$
pay to play
springs $200 + shocks $300 = $500+/-. if you can install yourself, you're saving a bunch of change GL!
OR, check the classifieds for a used setup
Old 03-19-08, 06:46 PM
flipicanez
flipicanez's Avatar
Trust me, get the shocks installed at the same time. You will kick yourself in the sack if you don't.
Old 03-20-08, 09:28 AM
ZippyGuy
ZippyGuy's Avatar
Yes, you can
Quick Reply: L-tuned ???'s
