View Poll Results: When did your ball joints go out?
50-75K
16.98%
75-100K
12
22.64%
100-110K
13.21%
110-120K
1.89%
120-130K
7.55%
130-140K
13.21%
140-150K
5.66%
150-160K
1.89%
160-170K
0%
170+
16.98%
Voters: 53. You may not vote on this poll
When did your Ball Joints go out???
Old 04-06-08, 05:28 PM
Drag On
Drag On's Avatar
Originally Posted by 1SICKLEX
I was at Hennessy Lexus of Gwinnett today and had Nuum inspect them. He said he recommends changing it so I am....$450 plus.....
I have 160k miles and did hear some creaking and its time for a change.
Do it youself. Ball joints are $110 from Sewell and you can install them in 2 hours with basic tools. You'll need a jack and stands, 17mm and 19mm sockets and a breaker bar. Easy as pie!
Old 04-08-08, 10:24 PM
KurtK
KurtK's Avatar
On the fear of failure had mine replaced by a Toyota dealer at 98,000 miles GS400 1999 .dealer said "I would put the bucks into a timing belt etc rather than the unheard of ball joint rplacement" but I siad I wanted it done .. cost me 500$ just under
Old 04-08-08, 10:27 PM
LexFather
Guest
Posts: n/a
Already done, $400, $98 each for ball joints and CL member VVTi did the install so I know its perfect. Plus I have a great relationship with Henessy Lexus of Gwinnett so I don't mind spending the money, great dealer and people.
Old 04-08-08, 10:58 PM
GS_OREO
GS_OREO's Avatar
Couldn't have said it better.
Old 04-13-08, 03:50 PM
GS FONZy
GS FONZy's Avatar
I changed mine because they had a little play. The best price I found was Carson Toyota.
Old 04-14-08, 06:00 PM
MJImport
MJImport's Avatar
Originally Posted by Lyrical
Just a little curious with my car running on such high mileage...
To those who were unfortunate to have this happen to them, what mileage were you at when had your Ball Joints go out?
Also, does anyone know why the car 'Clunks/Clinks' when the ball joints are about to go out?
The sounds youre hearing are caused when the bearing surfaces wear enough that there is slack between them and they repeatedly collide.
Old 04-15-08, 08:57 AM
veritek
veritek's Avatar
I just ordered some from Carson, they are discounted for CL members!!
Old 05-05-08, 11:08 AM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
i think i changed mine at 52k
Old 04-18-09, 06:31 AM
airahcaz
airahcaz's Avatar
I heard that domestic cars don't have theirs sealed, so you can actually grease the joints.
A closed system makes more sense, but if they get that bad and faulty and can be dangerous, then wonder if it was a bad design.
Old 04-18-09, 07:37 AM
lexusscturbo
lexusscturbo's Avatar
I saw a GS with one broken on the 405S yesterday; blocked traffic for a few miles :errg:
I'm sure it wasn't a C/L member as it was dubbed and lifted haha
Old 04-18-09, 08:57 AM
sakataj
sakataj's Avatar
mine didnt go out....i believe in preventative maintenance. i replaced mine during my 90k
Old 04-18-09, 09:01 AM
Stage3
Stage3's Avatar
Same for me, except I did mine at about 180K.
Old 04-18-09, 09:05 AM
ZippyGuy
ZippyGuy's Avatar
Changed them at 60, then again at 78 when I had an accident, and changing them again at 105 since I'm making some changes to the suspension.
Don't plan on EVER letting them fail....or anything on the car for that matter.
Old 04-18-09, 09:30 AM
sam430
sam430's Avatar
I believe it's a lubrication issue...however, when you buy the joint, you will get the newer designed one that are less likely to fail. I replaced my 01 at 120k and it was in excellent condition...threw it away and sent one to a fellow CL member since I tore the rubber when taking it off.
vlogs300
Suspension and Brakes
48
02-24-18 07:53 PM
qwerty04
12
01-24-13 03:31 PM
memGS300
02-22-10 02:47 PM
girlilove
07-01-07 10:42 AM
Quick Reply: When did your Ball Joints go out???
