i'm not really sure what it could be..maybe LCA bushings? i've already replaced the UCA bushings w/ the Daizen camber kit, steering rack bushings, energy suspension sway bar bushings, and new tokico shocks/struts. it's getting really annoying, almost everytime i take off from a stop and letting go of the clutch it makes a screeching sound, what could it be?? another question..after i've replaced my clutch to a Spec Stage 3 it started making rattling noise at low rpm while driving only..i've read that this is a common thing on certain clutches..is mines having the same issue or did ***** up on something?
Someone loves his burnouts. :P
It could be the clutch. I have a Centerforce Stage 1, and when let out, it makes a chirping noise. Its kind of annoying, but I don't know how to fix it. I don't think its bad for the car or anything though.
Did you check the tension on your accessory drive belt?
well my belt right now is sqeaky b/c it's a cheap duralast belt from autozone...but i don't see how it could be that when i take off from a dead stop...?
Then type the words "screeching fan belt" into google and read all about it. Ideally your seals, belts, gaskets should be from Lexus/Toyota and not the chain stores.
i'm gonna go buy the gatorback serpentine belt to see if it helps b/c i've been reading a lot about it and people seems to be satisfied with it...
