STIFFEST suspension?
I think you might be a little misguided on the meaning of "stiff" in terms of suspension. 99% of the air suspension systems for the GS aren't considered sporty/"stiff". Also, just because the suspension is stiff doesn't mean it's any less likely to blow out under regular use.
If you are looking for something that is going be a firm sporty ride then you may want to look into the Tein Flex or JIC FLT A2's. They will give you about as firm as a ride as you will ever want and will go as low as you could want as well.
tochoks22
03-05-09 11:32 PM
