Horrible rear tire wear!!!!!!! Pro Kit
Old 04-25-08, 10:15 AM
  #31
ISF_GG
ISF_GG's Avatar
I think you're right. I have never heard of anything even close to adjustable links for our cars until this thread
Old 04-25-08, 03:00 PM
  #32
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,024 Likes on 2,439 Posts
There are no camber adjustment kits for the ISx50 at this time.
Besides, camber's not the problem. Toe is.
Old 04-25-08, 06:46 PM
  #33
ep3turbo
ep3turbo's Avatar
i have no problems with my pro kit
Old 04-26-08, 01:47 AM
  #34
iialcii
iialcii's Avatar
had mine for about 4,xxx miles and Im starting to see inner tire wear on the front wheels. non on the rear
Old 05-08-08, 12:38 AM
  #35
gtr022001
gtr022001's Avatar
Yah, same here, inner wear is pretty bad with the Eibachs in the front.
Old 05-08-08, 06:05 AM
  #36
passnu2
passnu2's Avatar
did the OP get this figured out?? Post us some updates please.
Old 05-08-08, 08:49 AM
  #37
100plus
100plus's Avatar
Originally Posted by FiveOhNine
30 seems a little low to me. You could get wear on the inside and outside of your tires from running too low....couple that with a camber issue, and you might just get lots of inner tire wear.
But I don't think 30psi is low enough for what you're describing...it has to be something else.
Isn't Factory spec 37psi in the rear and 35psi in front?
Old 05-08-08, 11:33 AM
  #38
ba-b4
ba-b4's Avatar
about to get my suspension installed next week.. You people are getting me worried!
Old 05-08-08, 11:59 AM
  #39
FiveOhNine
FiveOhNine's Avatar
Yep...but 35/37 is a long shot from 30.
Old 05-08-08, 12:11 PM
  #40
javyLSU
2IS OG
javyLSU's Avatar
Wow, something's wrong - I've had my 350 Eibachs for over 2 years, and I've never had any uneven wear problems. My stock tires have over 25,000 miles on them (of which 18,000 came riding on Eibachs) and the tires are still useable.
Javier
Old 05-16-08, 05:17 PM
  #41
dw8787
dw8787's Avatar
Originally Posted by Drelicious
Thanks for all the advice guys! Im on the stock rims and the tire i am using is the Goodyear F1 All season. I just got my alignment done last week and they said that it wasn't that bad. I also asked them what the problem was and they told me "It looks like its spinning"? But even if they were spinning it wouldn't wear out that quickly. And i never drive my car hard. He says that just because i am 19 years old in a IS350!
I do have one question. Are you spinning your tires? Sounds like you are. I agree an occasional spin isn't going to do that, but you spin enough and you will see wear. I think you ask 10 people on here what their definition of driving hard is and you will get 10 different answers. I have a friend that went through a couple sets of rear tires and would swear his tires were defective. He used to spin his tires all the time. But he never saw it that way. Either way, go have the alignment checked by an different shop like everyone suggest and see what they have to say.
I don't understand on some of these threads where people say they have a problem, other members offer a lot of good suggestions, but they just keep complaining about it and don't seem to follow the very advice they ask for.
Old 05-17-08, 01:54 AM
  #42
VIS250P
VIS250P's Avatar
Why you scare about the horrible tire wear? If ya worry about rubbing, scrape, or bald tire then dont LOWER IT..
Old 07-24-08, 12:05 AM
  #43
XGenX
XGenX's Avatar
30psi is too low, go with the recommended psi on the tire side wall. i think it's 40psi
Old 08-14-08, 06:42 PM
  #44
timucla
timucla's Avatar
I've had pro-kits on my car for around 4000 miles and haven't had a problem with tire wear. I agree, I think the psi is too low.
yardie876
01-17-17 06:44 AM
uncandid
07-03-12 03:16 PM
Bigrahizzl
Suspension and Brakes
04-02-11 07:01 PM
IS_250
12
01-31-09 09:40 AM
CCC-TT
17
05-19-07 06:48 PM
Quick Reply: Horrible rear tire wear!!!!!!! Pro Kit
