**Official Alignment Info for ISx50**
I'm not quite sure what's the point of this is though. If there is only toe adjustable then isn't one post enough about what the ideal toe should be and that's it? I think the differences in camber change are due to people having their cars lowered at different heights with different suspension kits. Since it's not adjustable anyway there's nothing you can do about it so I don't really see the point.
I am sure if everyone keeps posting you will see in the future how beneficial this can be. Especially for the guy like me how does it himself!! I have a nice luxury to go visit the dealer after hours and I just TIP the guys for there time and help!
Mike
^ yes I understand that you want to be helpful but I don't see how everyone posting their settings really helps still. It's either you can get back into spec or you can't. I guess with this thread you can see with what each setup how far off spec you are???
Passnu2,
It looks to me like your alignments specs were slightly better BEFORE the alignment since they increased toe on your front and rear. Toe-in causes increased tire wear, while also increasing understeer. I don't have my alignment specs in front of me, but I specifically requested 0 toe in front, and .08 rear so I could reduce tire wear while also improving handling.
I would be curious to see yours...I am not expert but how it was explained to me was that the Toe-in was what you wanted (to an extent). Once you start to drive they move out and then give close to what you have as normal set up (being 0 Toe)? so with your 0 Toe when the car starts to accelerate you are Toe out then correct? It made perfect sense to me and this is the dealer that did it for me. They are a large group of dealers under one name (Lexus being one of them!)
I have no tire wear issues either....
If anyone one wants to take it to the next level please do. I am not sure how much longer I will have my car so its best a more active person with the IS takes it further. I also thought it would be helpful info for the DIY people on here as that is pretty much how I do all my stuff and if I need to I go to the dealer after hours and use the stuff there. They are really nice to me there. Nice to be friends with the owners
Does this seem off to anyone else?
Edit: Stock lux suspension, Work 18x8.5 (225/40) front and 18x9.5 (255/40) rear.
Seems like my caster is still off on the left, my toe was way off in front, and my right rear toe is well outside of the range. Any ideas/advice/suggestions/comments for an alignment newbie?
And for my troubles, this is what I got:
In case you can't tell from the crappy cell pic, they sliced my sidewall (about 1/8"-1/4" deep) and gave me about 1.5" of curb rash.
