More camber on one side than the other
Old 04-27-08, 02:47 PM
Lexbox
Lexbox's Avatar
Default More camber on one side than the other
My back right tire looks cambered way more than the rear left. When I got an alignment the guy didnt say anything about it. It doesnt ride rough or anything. They are the same height. Tein CS v2. Any ideas?
Old 04-27-08, 03:36 PM
Debonair
iModerate
Debonair's Avatar
Did they give you a copy of your alignment specs? Check there first for uniformity or obvious differences.
Old 04-27-08, 06:06 PM
4ntvings
4ntvings's Avatar
try to get a hard copy of your specs
then review the toe/camber/bla bla bla data to get close to spec
Old 04-28-08, 10:36 AM
Lexbox
Lexbox's Avatar
To recap on my current mods. Tein CS v2 dumped ALL the way in the front. Two visible threads in the rear. Coilovers have settled alot since I put them on. No ICE in the trunk. No extra weight. 20" Donz Columbo's with offsets(no fender modification) recommended by Derek @ D2.Please advise.
Attached Thumbnails More camber on one side than the other-alignment-specs.jpg
Old 04-28-08, 10:45 AM
GSteg
GSteg's Avatar
How long after the coilover install did you get your alignment done?
Old 04-28-08, 11:02 AM
Lexbox
Lexbox's Avatar
Too long. I shredded my Toyo's because of it. Maybe 6+ months. Got the Falken's put on in September and had the alignment done then.
Old 04-28-08, 11:03 AM
Debonair
iModerate
Debonair's Avatar
All your Cambers are out of spec (expected) but not drastically different from each other. The right rear has 0.2 degree Less Camber and 0.08 degree More Toe which I don't think should not be noticeable on the Eye-Ball scale.
The Plot Thickens...
Some one else with less rusty knowledge may need to chime in and clean up after me since it has been 3+ years since I have even looked at a alignment spec printout.
Old 05-05-08, 05:08 PM
sockfocks
sockfocks's Avatar
Its possible the alignment may have changed since its been done. I know one of my control arms has slipped in the past.
Old 05-07-08, 07:44 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
yes a alighnment can change especially from potholes
Mikerx80
07-22-15 09:42 PM
Stevoe88
Suspension and Brakes
07-27-11 12:31 PM
vip..me
03-31-11 07:24 AM
sleeper408
02-23-07 05:34 PM
blaznsc4
05-18-05 08:02 PM
Quick Reply: More camber on one side than the other
