Tein SS settings
Post up your settings and explain the type of ride your getting.
13f/11r, this is alittle too stiff on normal roads BUT... on my local touge run its simply fantastic. I had it at 9f/7r but it was just alittle too floaty, firmed it up due to lowering it more.
so... whats the point of this thread? if you think you've found the perfect dial in, post it up.
(i wanna know
*edit* ok 12f/9r and it feels great
![](http://img363.imageshack.us/img363/6149/iconthumbupjh3.gif)
ok thought i'd update after riding around awhile... my fronts are at full slam = springs are at max stretch (uncompressed) so very bouncy, i've since adjusted my front to 15clicks (16 is max)/5ish turns from full slam rear (9clicks), getting a better ride.
Course one thing im debating on, since i have to use the stock upper pillow mounts i wonder if i could swap the SS spring for the eibach one... wonder how that would feel at full slam, i wonder if they would fit
