Review: F-Sport Springs and F-Sport Bilstein Shocks
Tech Info Resource
See this post for how to adjust the lights very simply and correct the problem at the source.
That bone looking piece in the rear if they didnt alter or move it when the installed the springs you shouldnt need to mess with it. I did not move or adjust it on mine and its in the same position as what lobuxracer posted in that thread. you should be able to see it from the rear with out lifting the car and its only on the rears.
Cant wait to see your car
Tech Info Resource
It will, but the problem is that the AFS sensors think the car is not at stock height anymore. Adjusting the AFS is a single 10mm nut. Loosen, adjust, tighten, DONE. If you mess with the light adjustments, you'll have to adjust both and you'll have to adjust both horizonal and vertical. I'd call loosening one nut, adjusting, and tightening a whole lot easier.
Thanks for the help guys. I will see if I can find the nut for the AFS sensor. No rush. I just get flashed a lot
No alignment was included. I would have declined anyways. Going to someone else.
Tech Info Resource
Yes, but the sensors it uses have adjustments so you can get the headlights aimed correctly just using the AFS adjustments. When you change the attitude of the car (pitch axis), the sensors aren't telling the AFS ECU the truth anymore, so you need to adjust them until they do.
Update:
Recently, I have been hearing noises coming from the suspension. Occasionally, when I travel over bumps at high-medium speed I hear a "clunk" from the suspension (I think its the rear). This happens randomly (hard to duplicate) and only when I am on the highway. Any other F-Sport suspension owners hear this as well?
