Picture REQUEST. Non-Air Tucked Wheels
#181
also, odd, i couldnt achieve 0 gap in front w/my CS
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#182
Did you mean 245/40, and that's probably the cause for your rubbing problem. Technically your tires are over sized and prone to hit the splash shield more than a standard tire set up.
#184
I feel stupid asking that too, but I kinda wonder how you can drive that low. Like if you hit a bump while turning, the tire doesn't hit the fender or do you have to turn and drive very very carefully?
I'm not planning on anything real extreme, I'm thinking DF210's should be low enough for me but I'm a little concerned about being that low on 20's with the "fat" setup, 245/35 and 275/30. I've got L-Sportlines that I gather are pretty conservative by today's standards, 8.5 f and 9.5 r with 44 offset all around and I don't mind doing a little massaging of the fender if necessary; but I'm worried about being able to turn without problems if I'm almost tucking the front tire.
#185
u should be fine with that set up..44 offset will make ur rims sunken in anyway..i had 19x8.5 +45 all around..no rubbing at all..and i was on chopped df's..i was running 235/35 all around also..so u should be fine..if anything a little rolling is all u'll need
#186
ok finally took some pics with the TEIN SS's
![](http://i58.photobucket.com/albums/g259/TeeRdeeD247/CIMG2507-1.jpg)
![](http://i58.photobucket.com/albums/g259/TeeRdeeD247/CIMG2510.jpg)
ordering some H&R spacers soon to flush it out![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
the Fronts are maxxed (2 donuts cut off bump stop) the rears can be dropped another inch and a half if i cut 2 donuts off the bump stop. (in which i forgot too
sorry digicam suxas and gs is dirty!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#188
#191
Looks great man!
whats the offsets of your wheels?
#194
Thanks for the reassurance.
