hahaha..props on fitting those wheels tho..although ur car was already sick before all the fender bashing..i still look forward to seeing the final result of ur build..keep it up bro
hahaha thx man, but the rears have always been pretty pulled (my stupid mind set of ah they can fit and every wheels I get keeps getting more and more aggressive hahahhaha) but as long as all goes as planned I will have the time to change them one more time along with cleaning them up to at least primer) fingers crossed.
Originally Posted by bluwagun
Fullmoong, your a boss for doing your own fender work. I can already picture what the end results will look, when finish. Keep it up
Thanks I am not big on leaving my car at to many shops to have work done (trust issues from the past hahahaha) so it has let me no choice but to do it my self hahaha
Here is my gs with my new wheel set up. (And this it the last time it will be posted up with the jacked up fenders since I finally found wheel specs that I like)
hows ur camber wear on ur rears??
im going through tires every 3 months...
ur toe is probably bad...get adjustable rear toe links and have the alignment shop correct it....i have -6 on rears and my tires last for some time...its the toe that normally messes it up not the camber...
Its bad lol
Im at -7 up front & -11
But I cant say how long my tires last because I mess with the camber alot & I popped two tires after a month or two of having the tires.
but I think I am not going to touch the rears anymore.
As for the fronts I wanna go lower
Hope that helps answer your question
Its bad lol
BP thats awesome...what kind of suspension components did u get to get those numbers?...I like my mild setup right now...but maybe in the futre id like to get more negative camber
hem...so i guess i have to adjust the toes..
but i cant make it up to the alignment...its way too low..
i tried every shop around my area but they said no...
