Picture REQUEST. Non-Air Tucked Wheels
#601
yep thats true!
4play your name is rickey right?
what is your coilovers preset to? as far as the softness/hardess (how many clicks?) also with that stance you have now how many perches(full turns) do you have left or how many inches is it from the locking spring seat to the top of lower bracket?
#602
kinda confusing with the questions..but my front damper is set to fully stiff..and the rear is set to probably half way in between stiff and soft..my front preset is close to all the way..not sure how much is left on the preload..but maybe another 1/2" and ofcourse theres still the lowering from the spring perches..which probably still has like 3-4" MORE to go lower!!
as for the rear..the preload is maxed out..and i lowered it from the spring perch maybe 1/2"..and still..there is a good 3-4" left to go even LOWER!!
JIC doesnt mess around with their products man..if u want slammed..they'll give it to u
hope this helps
btw..did u receive ur JIC's yet?
#603
sorry man to confuse you. im new to the suspension lingo so i wasnt sure if i asked that correctly but you answered it perfectly hahaha
Im sure when you first installed it, it took awhile for you to adjust to your perfect stance. I was just trying to get an idea at where your at so i can compare when i do mine.
Ahhh man impatiently waiting they should be in tom hopefully
rays: but definitely this week.
#604
ah yeah also.. since im on stockies im sure the rear will tuck in no problem without any modification that low right? but what about the front..? would i be able to tuck tire in the front without worry about rubbing when i turn the wheel left or right?
#605
you might need to shave your fenders for your front. i remember when i first put on the Flex's my car was a little lower than 4play4dr's. i was rubbing on every bump in the road and everytime i turned the wheel. granted i have 60 series tires but i dont think that matters.
but thats if you decide to go that low
#606
but for the meantime since im on my stockies i just want to get ready for what needs to be done before/after the install.
thanks man for the advice much appreciated!
#607
I do plan on going as low as the roads let me. i plan on of course later on cutting a hole for my upper control arms and pull/shave/roll the fenders once i decide on my wheels.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
#608
when i first slammed all the way on my flex, i wasnt rubbing anywhere. my stock 16's are on 225/55's and i even removed one of the three perches up front, i still wasnt rubbing (well, maybe the underbody, but thats not rubbing, thats grinding =]) but yea, forget about fender mods being slammed on stocks unless u got bigOtires ![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
thanks man for your input!
#610
how did u get mud guards? universal ones? lets see a better pic..never seen that before..
but as far as the slammmed on stocks..i did and it was fine..no rubbing for me either..and i too had 55 series i believe..when i first installed my JICs i had the preload set all the way down all around..the fronts was slammed..but i dint have my hole cut yet..so the noise bugged me..so i raised the preload a few turns and it was fine..a lil bit of knocking..but it wasnt too bad..then after i got the wheels on..i jus decided to leave it at that height..and its fine to me
#611
when you guys are talking about preload your meaning the spring perch that holds the spring up right? why would you be adjusting that up and down all the time, doesnt it just get left where the spring is snug? (unless you want them a bit harder). And you adjust from the bottom bracket?
#613
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![](http://jic-magic.com/images/Products/P-34-1.jpg)
#614
to make my question simple all i was asking rickey was how many inches (or full turns) does he have between #5 and where #7 is (which is the top of the lower bracket).. this is just so i know where i will be when i adjust them.
