Please direct me to the abs sensor with pics
Hi all
Im having an issue trying to figure out where my abs sensor cable is at. I dont even know if its on left and right or just left. Pics would be very much appreciated and please let me tell you that yes i have searched and came out blank. please help cause abs, vsc vsc off lights are killing me
thanks
thanks
The wire is the one that's held into the shocks.
If you have a multimeter at home, measure the resistance of the speed sensor. The connector is located behind the fender liner. Just pull the plug (connector) out and read the resistance. It should be 1.4k-1.8k Ohms. If not, then it's broken. If it falls within the range, then the sensor is good and the problem is somewhere else.
abs
It's all great info.. But I am still a bit foggy. Is it called the abs sensor or speed sensor?? All I see a cable. So is it a sensor "cable" that needs to be replaced?? Or is it a module type sensor attached to the cable.. A little confused. Any clear up will help.
Thanks. I was told my right front "speed sensor" is going bad and it is causing my indicators to come on and stay on. What ever that is.... Help!!
Rock
Rock
gsCrazy
03-20-17 09:26 PM
drewefx
05-17-08 08:13 PM
