rear hub bolt torque?
Does anyone have the torque spec for the big hub bolt for the rear driver side? I've been searching the forum and can't find it. Any help would be appreciated, my car is a 98 GS400.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
SS-54
SERVICE SPECIFICATIONS - SUSPENSION AND AXLE
Author: Date: 211
2003 LEXUS GS300/GS430 (RM974U)
Part tighten N·m kgf·cm ft·lbf
REAR
Hub nut 103 1,050 76 HERE it says 76 ft pounds. for 2003 GS 300/430.
Brake caliper x Axle carrier 104 1,065 77
Axle carrier x Upper suspension arm 108 1,100 80
Backing plate x Axle carrier 59 600 43
Drive shaft x Axle hub 289 2,950 213
No.2 lower suspension arm x Axle carrier 110 1,120 81
No.1 lower suspension arm x Axle carrier 75 765 55
Drive shaft x Differential side gear shaft 68 695 50
Differential drain plug 49 500 39
Differential filler plug 49 500 39
Differential mounting bolt Front
Rear
123
142
1,250
1,450
90
105
Ring gear set bolt See page SA-74
Companion flange lock nut See page SA-74
Differential carrier retainer set bolt 22 225 16
I have a 6mb file of PDf's that you can have if you want. It has some
random stuff in it. just PM me.
JimsGX
08-15-10 07:15 PM
