People who used Lowering Springs
so for the people who used after market lowering springs... did you guys noticed that once your springs settled in, the wheel gap in the rear is smaller than the front. As in the rear of the car drops lower than the front. not by a lot but like a little???
Wouldn't tire size have a lot to do with it as well. You guys should post tire sizes because some people have bigger rolling diameter differences between the front and the rear.
I have less then a finger if that of a gap in the rear. more of a gap in the front but Its because I am on springs and the tire sizes I chose. I could have gone smaller in the rear and had similar gap front to rear.
It also depends on what springs you get. Many lower the car LESS in the rear the the front. Its how the car sits. If you want the "PERFECT" front to rear drop regardless of rim and tire sizes....you shouldn't be looking at springs. Ask sincityIS to chime in since he has had both on his car!
I wanted to keep and let my wife take the car over but I fear her driving in the snow with RWD. She is used to FWD and the though scares me. Time to move to a warmer climate
But I agree for the $$ the TeinSS are the way to go as you can still soften them up if you want but get nice and crazy if and when you want! This would suit me just fine! You can get them used pretty cheap now. I have paid attn to them in the classified section lately
How about you? Plan to keep it for a long time??
So if the rear drops more and if you keep the wheel diameters similar to the original 18" setup, won't that mean if you've got 3 people in the backseat the tires will always rub whenever u go through bumps and such?
Reason I ask is I'm debating on whether to get the F-Sport springs.. I upped my wheels from 17"s to 18"s with 225/40 18x8 +35ET front and 255/40 18x9 +39ET rear recently and noticed with stock springs I have slightly more than 2 finger clearance at the rear and 3 at the front.. The F-Sport springs will drop it 1" and I'm worried that it might rub at the rear when I have passengers on board..
Thoughts?
Thoughts?
Thoughts?
Thoughts?
